Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
How to include a script in Timeline? Need your help!
3 REPLIES 3
li71we
630 Views, 3 Replies
I am working on a timeliner simulation in Navisworks.
But I have a question on how to use script, I create a script,  a gate will open if the truck is closing to this gate(I have created a gate auto open animation), my script is On Hot Spot Event type, if the truck is moving to the position withing 3 meter from the gate, then gate animation will be triggered.   Also, truck moving is an animation.
Question: 1) Do I need to include script in the Timeliner and setup Start time and EndTime.
                 2)Do I need to include the Gate Animation and Truck Moving Animation in Timeliner and setup Start time
                    and End Time.
Does anyone can give me a guide on how to create a script and how to use it?
Jian
3 REPLIES 3
fernanda.firman
in reply to: li71we
Kindly refer to the document below.
http://aucache.autodesk.com/au2009/sessions/5204/AU09_SpeakerHandout_CR122-1.pdf
Hope that helps.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
PAyre
in reply to: li71we
That is very good guide but I believe the question is how to use the hot-spot trigger in a timeliner animation and the answer is you can't, they just don't work during a timeline animation.
The workaround is to link the gate animation directly to a task in timeliner. This works because your truck will always arrive at the same known time in timeliner.
Hotspots are ideal fore when you're moving around the model or running a viewport animation and need an event based on proximity.
fernanda.firman
in reply to: li71we
Thanks for posting!
Autodesk, Inc.
Revit Clinic
Rail Community
