Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
How do I Remove a merged/Appended model from nwf in Navisworks
15 REPLIES 15
Message 1 of 16
19181 Views, 15 Replies
Hi
Can anyone please help me. I understand I can't remove a merged dwg from from an nwd but is there a way to remove a dwg from an nwf without hiding it. There must be a way to completely unreference the file from an nwf.
15 REPLIES 15
Message 2 of 16
In the selection tree you can right click on the file and choose delete
Message 3 of 16
I cant see the detete option when I rigth click the object in the selection tree
Message 4 of 16
Light_Guy
Anyone have any updates for this thread? I have run into the same problem. Simply right clicking in the selection tree does got get me a remove/delete option. I am using 2014/2015 Manage (both versions have same issue)
Paul Hamor
"Always good ships!"
Message 5 of 16
Light_Guy
in reply to: Light_Guy
OK, I did notice that once a second item is appended, you get a delete option from right click but you can only delete one. Once you delete that one, the option disappears for the remaining item.
Paul Hamor
Message 6 of 16
You should use the "standard" view on the selection three
Then you should select the file in the tree.
Then you can use the "delete" key of your keyboard.
If you want to remove more than one file, it is a known issue that Shift+Selection to select a range does not always works.
But it always works for me in the following sequce:
Scroll down to the last of the files that you want to delete.
Select it.
Select the one above also using Ctrl+Mouse
Then scroll up
Then select the most upper file using Shift+Mouse
then use the "Del" key on your keyboard
Message 7 of 16
jglynn
in reply to: Patrick_Aps_9121
 I'm currently experiencing this exact same problem and none of the suggested solutions have resolved the issue on my end.
 > Using Navisworks Manage 2015
 > I am working in the nwf.
 > The Selection Tree is open and Standard mode is active.
 > Right clicking on the appended file/dwg does not show a "Delete" option, nor does my delete key have any effect.
 I have also tried creating a brand new nwf and appending a few dwg's, however the issue persists even in a new file.
What I don't understand is why this is even an issue. Being able to "delete" or remove files is a common and necessary function of software and yet here I am unable to do so.
Message 8 of 16
Patrick_Aps_9121
in reply to: jglynn
I'm not sure if you really have a bug or if it is a matter of user interface
I start a new NWF, append some DWG
Then in the selection tree, select a DWG (do not click on the + sign, click on the filename)
Then in the right mouse menu, there is Delete
OR
When the file is seleted, the "Del" key in the keyboard works.
Message 9 of 16
Light_Guy
in reply to: jglynn
<meta http-equiv="Content-Type" content="text/plain;" /> body { font-family: "Calibri","Slate Pro","sans-serif"; color:#262626 }
What I have noticed is that there has to be more than one file appended. Once the second file is added delete gets turned on but when you are back to just one file it foes away again.
Sent from my BlackBerry 10 smartphone on the Verizon Wireless 4G LTE network.
Paul Hamor
Message 10 of 16
naturally, deleting the 1st appended file will end you up with an empty file. That cannot be done but the workaround is simply to start a new, unnamed.nwf
Message 11 of 16
I'm having the same problem.
I have to delete the item - because if someone unhides it later it (by using unhide all) it will only confuse them.
I tried all of the suggestions above.
Thanks.
Best,
Hayat
Message 12 of 16
Patrick_Aps_9121
You cannot delete the selected file because the file you have opened is an NWD and not an NWF. You need to open the NWF that is used to create the NWD, then select the file in the Selection Tree (please notice that in your screenshot you are in the Compact mode, not in the Standard mode) and then you can use the DEL key on your keyboard.
Message 13 of 16
Thank you for your fast reply!
Sorry, I just started learning how to use this tool. Should I always be working in a NWF-file?
Message 14 of 16
dgorsman
That depends on your work process.  In most cases you would be working with the "raw" models (Revit, Plant3D, etc.) in an NWF because you need up-to-the-minute content.  If you are only responsible for reviewing the models somebody else may be publishing the NWD files because they know precisely which models should be present, proper colors, and so on.
Message 15 of 16
mark
in reply to: dgorsman
To be able to right-click and have 'Delete' as an option, you can not have the Clash Detective window open. You have to access the files you want to delete through the Selection Tree only.
Message 16 of 16
thanks man, this really helps.
Rail Community
