Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
How Do I export a Naviswork's Models Grid Lines????
5 REPLIES 5
Jeglum
2221 Views, 5 Replies
I wrongly assumed this would be more simple then it actually seems to be.
I have a very complex Model Sent to me in .nwc file format.  It contains the gridlines (in addition to the entire model) for all the buildings and areas interlinked.
I need to export this to AutoCAD or Tekla, (Not the model... JUST the grid lines)
I simply need the grid lines.  However, when I convert it, I no longer have the gridlines in the converted model.
Please let me know how I copy the grid lines from a Navisworks .nwc file to ideally an AutoCAD dwg file.
The only available file containing all the grid lines is that single .nwc file.
Thanks in advance
5 REPLIES 5
Jeglum
in reply to: Jeglum
Nevermind, went A different route
smbrennan
in reply to: Jeglum
For future reference, the grid lines are generated when someone exports a Revit Model. I have not heard of anyone trying to export the grids only. If you do need the grids, you could always export a Revit View with the grids.
Shawn B.
To help improve Autodesk Products, please Click Here to Vote for ideas and submit your own.
Grid are used in a lot of other programms too, and they are even described and exchanged in IFC files. It would be nice if we could echange grids between appications using IFC or a neutral XML format.
Below in my signature you can find a link to provide feedback. They do look at requests and keep a log. I have personally received multiple follow up emails for requests I have placed.
Shawn B.
sureshchotrani
in reply to: Jeglum
From Revit export grid lines in dwg directly, you can now import this in any model:)
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Rail Community
