I don't see where you tell how this Attribute File is Created in PDMS. Can you also tell me if there are setting that need to be changed in the Gobal Options in Navisworks to make sure the PDMS RVM File is received correctly?
Hello. If you search the Navisworks Help file for "RVM" it will give you some options for this file type.
If you open the Options Editor and click File Readers > RVM, you will see the RVM options.
You want to keep the attribute file in the same folder as your model file and you want to make sure your file has the correct attribute extension, as listed in the options file.
Make sure the “Covert Attributes” box is checked as well as the “Search all attribute files”.
If you have already loaded your model once, delete your NWC file and reload your model. This will create a new NWC file.
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
Hi ,
Step by step procedures
CRETAE A FOLDER - SAY TEST(/c:\TEMP\TEST)
- ENTER INTO PDMS
EXPORT AN RVM FILE SAY - PDMSATTRIBCHECK.RVM/PLACE IN THE TEST FOLDER
EXPORT DUMP ATTRIBUTES WITH SAME NAME -PDMSATTRIBCHECK.ATT(.ATT EXTENSION IS MUST) PLACE IN THE SAME FOLDER
Now go to navis
Right click inside the screen you will get global options.Enter there you get filereaders
Go to .rvm AND CHECK THE CONVERT AND SEARCH ALL ATTRIBUTES(REFER THE ATTACHED FILE)
Load the rvm and generate nwd NOW IT WILL WORK I HOPE IT WILL SERVE THE PURPOSE
Hi ,
- ENTER INTO PDMS
Now go to navis
All, I have successfully dumped attributes from PDMS into Navisworks, as recent as last week. But now when I do it I cannot see the attributes in Navisworks. It loads the RVM and the ATT file but the PDMS properties tab is missing. See attachment for the previous successful attributes dump. This PDMS tab doesn't appear now. Can anyone help?
