Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Help! About the presence/absence of an object using Navisworks?
2 REPLIES 2
jhet
521 Views, 2 Replies
I have a Architecture Model and Structure Model overlapped.
It's very convenient to use Navisworks to check clashes and export the report.
But I also want to make report about objects like beams or walls that appear on my Structural model but do not exist on Architectural model or vise versa.
Is there a way to make this and export the report same way like clash detection?
Please check the image attached.
Tags (3)
2 REPLIES 2
in reply to: jhet
What you've just done is pretty much your best best...............take a snapshot of the area/object and mark it up.  Also, link in the Structural Model into the Architectural Model, and Copy/Monitor the missing elements (Or at the least use them to locate like objects in the ARch Model.).
HTH
Mike
jhet
in reply to: jhet
Yes I think that is the best way I can do for now. Rules are just for ignoring certain clashes but for my case, I don't know yet if it's possible to make rule for this. Still learning how to use this though. Thank you for your response.
Rail Community
