Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Grids & Levels not active
2 REPLIES 2
2906 Views, 2 Replies
Hi All,
I am on a project using a PDMS model and I have Navisworks 2012 for review purposes.
From the Navisworks menu, when I select "VIEW" the "Grids & Levels" menu option is grayed out, not available.
I wanted to use this to select elevation levels in the model, thus making the review process more efficient.
I have looked in User Manual, online, this forum but cannot find how to "switch on" or make this feature active.
Any help/tips/guide very welcome
Tags (1)
2 REPLIES 2
kishore152
HI, May be you can check the settings before you export to Navis works...like any checkbox to export grids and levels
Patrick_Aps_9121
To my knowlegde, the only "grids and levels" that are recognized by Navisworks are the ones created by Revit. I also would like to have to be able to define "grids and levels" in the Plant Design models but still in version 2015 there is no change in functionality.
Rail Community
