I have all of the Service Packs and Hotfixes installed.
In Navisworks Manage 2013, and prior to the service pack install on 2014, when I zoom in and out of views the gridline tags stayed at the perimeter of the screen. After the install they now are only visible at the ends of the gridlines and do not move with the zoom.
I am not clear if this is an issue specific to a particular project with the latest Navisworks updates, or occurs with all projects.
If you create a new project, create some gridlines and bring it into Navisworks, do you see the same behavior?
A Chronicle video (or a video from another screen recording utility) showing the steps you are going through might also help convey what you are seeing.
This is still happening, on all of my projects (3, right now), all of which were working fine in Navisworks 2013, and which come from Revit 2011 and 2014, by two different model creators. In one project I have three different Revit models (as NWCs) in one NWF and regardless of which grid I select the tags disappear when zooming in.
Still happening.
Kind of funny, I keep getting emails from Autodesk support about my "ticket", presumably from posting here, but with no resolution.
Have you been able to resolve this issue? The same thing is happening to me?
I've found that this issue has been reported to our developers and should no longer occur in the 2015 version.
