Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
From Timeliner to 3DS Max
16 REPLIES 16
Message 1 of 17
4745 Views, 16 Replies
Is it possible to export a construction sequence to 3DS Max in order to render faster with better resolution.  Our clients are asking for 3DS quality videos, but takes too long to set-up manually in Max.
16 REPLIES 16
Message 2 of 17
DarrenP
i don't think you can export out animations from navisworks
DarrenP
Message 3 of 17
in reply to: DarrenP
Doesn't make sense - clients want photorealism and we are still delivering cartoons.
Message 4 of 17
dgorsman
It may not be photorealistic but Simulate *is* accurate technically - something media-centric animations lack.  If you want both realism and technical accuracy that requires a major investment in hardware, software, and training.  Thats usually beyond the scope of work for engineering companies that use Simulate, so in the rare cases its part of the client requirements it typically gets contracted out to a media production company.
Its also important to educate the clients on whats possible, whats needed to get the results they are looking for, and the costs and time involved.  Most client reps are not technical types but management who only know "Hey, that looks cool!  Lets do that!".
Message 5 of 17
niranjan_kamath
I agree with dgorsman, Timeliner simulation is different from a normal animation. It uses the project schedule either in MS project, primavera or Excel format to link with the 3D model on the project which then simulates the construction based on the schedule in the linked project file. The Simulation seen in the Timeliner is accurate to the scheduled start and end dates as per the linked scheduled file.
On the other hand 3DsMax is not a simulation software. It can only animate the model. 3DsMax cannot link any project files and perform the construction simulation based on a scheduled time frames.
In case the client is insisting on a 3DsMax animation then the only option we have is to bring the project to Max and prepare the animation completely in Max. the timeliner sequences cannot be exported to 3DsMax.
Niranjan Kamath
Autodesk, Inc.
Message 6 of 17
There was a class at AU where a company did just this with a script accessing the API.
The class was called "BIM and Gaming Engines: How We Present 4D Models Using Our Design Suite and Gaming Engines"
When the classes go up, take a look at the notes.
We have had similar requests, and are looking at implementing this work-around.
Message 7 of 17
jhiggen
We also have a request for high quality movies of timlinier animations. What was helpful is to install a new videocodec (xvid for example good and for free). When using the presenter renderer the result has quite good quality from my point of view. What is missing here is multi core rendering functionality because movies of 120sec take days to be ready. Does anybody know if one can replace the presenter render engine by a better one that allows multi core calculations?
Message 8 of 17
subpartner
This can be done, but it requires an HTML script from navis and an import script from max. It was shown at AU and just recently at RTC australia by Nicolas Broadbent from COX architects in Melborne. H e hasn't shared these scripts with autodesk or anyone to my knowledge, so its up to the users to request this feature on future releases.
Message 9 of 17
Does anyone know if the scripts have been released at all? I use Navisworks to produce time-realistic construction sequences but rendering takes a lifetime and the quality of the videos are poor. I'd like to link the timeliner to 3ds max like the guy does in this video: http://www.youtube.com/watch?v=9_pn63MmNGg
Message 10 of 17
Anything further on this? would love to be able to set the timeliner in Navis and export for rendering in 3DS.
Message 11 of 17
I'm afraid not, as said above it has been shown a couple of times and I have seen a few video's where people are using the script, but nothing has been released...
Message 12 of 17
Logos_Atum
Hello there, beeen looking for the very same script or at least a hint on how it´s done too.
I managed to find the AU Class 2011 Handout but it´s not specific. AB5801 if this helps....
I tried to contact Mr Broadbent- no answer so far. I used: Nicholas.Broadbent@hotmail.com
Even if he does not give away the scripts for free, a how-to should include the "how" part 😉
I opened a thread in AUGI. Perhaps there´s a recording of the class to be found somewhere.
Kind regards
Daniel
Dogs aren´t flammable.
Message 13 of 17
rgilbim
in reply to: Logos_Atum
I Also looked everywhere even contacted some of the private people that have done it. But no luck. Not even for purchase. Im sure it would take Autodesk nothing to build this in. Ugh! 😕 I also requested it under features.
Message 14 of 17
klaasnienhuis
in reply to: rgilbim
Anyone interested in bringing over the timeliner task simulation from Navisworks to 3dsMax should take a look at this tool: http://3dstudio.nl/webshop/product/69-navisworks-timeliner-to-3ds-max. It enables you to really enhance the visual quality of the simulation with everything that's possible within 3dsMax. This video overview gives you a good idea what's possible: https://youtu.be/6R6SgeZoaj4 full disclosure: I've written the tool. Best, Klaas
Message 15 of 17
J450NP13
Good job,  I will have my co-workers check this out.
Message 16 of 17
Logos_Atum
in reply to: klaasnienhuis
Thanks a lot!
Message 17 of 17
nick
Hi Julian boswell and Blairous,
I'm nick broadbent I did the talk at AU on BIM and Gaming Engines .
What are you trying to do in Unity?
Can you send me any samples or examples of what your trying to achieve?
I would be happy to help you out.
Rail Community
