I have installed Navisworks Freedom 2012 64bit version on a brand new laptop with Window 7 Professional 64 bit operating system.
I am trying to view a 3D model consisting of several .NWD files. I can open one at a time, but not several simultaneously, which worked fine on my old computer with Freedom 2010 32 bit version.
I get the following error message before the program shuts down:
"A software problem has caused Navisworks Freedom 2012 to close unexpectedly".
Anyone now have to solve this?
Solved by dembkod. Go to Solution.
Ninja230 ,
Hello. You would need to open all your NWD files in Navisworks and publish to one NWD file and open that one file in Freedom.
If you are really interested in having multiple file functionality, you can request it directly from our program managers. The more requests we get for this function, the greater chances of the function being implemented.
You would request this here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
OK. Thanks for the promt response. I will see if i can get all the files combined in one and see if that does the trick.
What does one do if access to Navmanage is overly dificult. Is there a patch that can be downloaded to allow opening of 2 or more models simultaniously?
