Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Fixing Paths on Exchanged file sets
3 REPLIES 3
shaunfarrell5867
1063 Views, 3 Replies
How can you easily change all the paths when you move a navis project from one office to another? If I have 100's of linked files I do not want to reload them one at a time. Is there a way to batch change all paths like REDIR in Autocad?
Or does Navis now support relative paths?
Cheers
S.
3 REPLIES 3
You might want to check if this is helpful and resolves your issue:
Navisworks Linked Files - Absolute vs Relative Paths
http://bimboom.blogspot.com/2012/12/navisworks-linked-files-absolute-vs.html
Hope this helps.
Holger Klöcker
mwaldron
in reply to: Holger.Kloecker
I had already found this page - it works with the NWD but not the NWF.
The good old dos-command SUBST can help.
OR cou can correct the NWF by opening the NWF
then brouwse the the right file when this is opened
repeat this 3 times or so
then hit ignore
then start re-appending the missing files
Rail Community
