When I use the Find Items window and add multiple item lines, it will show the "No objects found" message.
I have attached an image.
When I run each item line on its own it will find the items. Is there a setting that I need to set so that the AND condition will work?
Thanks.
They would be automatically AND conditions unless you have OR like in this case. So in your example you would want
Item Name = FORKLIFTTRAFFIC
Item Name = SPEEDLIMIT
OR
OR
Can you let me know how you get on?
I believe the selection is AND by default, so if you have NAME = 'Fred' and NAME = 'Wilma', nothing can be selected since nothing can have a single property (NAME) that is both. You need to explicitly set each line as logical OR.
