Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Find Items Not Working
3 REPLIES 3
2006 Views, 3 Replies
When I use the Find Items window and add multiple item lines, it will show the "No objects found" message.
I have attached an image.
When I run each item line on its own it will find the items.  Is there a setting that I need to set so that the AND condition will work?
Thanks.
3 REPLIES 3
lee.mullin
They would be automatically AND conditions unless you have OR like in this case. So in your example you would want
Item Name = FORKLIFTTRAFFIC
Item Name = SPEEDLIMIT
OR
OR
Can you let me know how you get on?
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
adminict
Hi gilbertm
Did you get a solution to this problem, I am experiencing the same too
dgorsman
in reply to: adminict
I believe the selection is AND by default, so if you have NAME = 'Fred' and NAME = 'Wilma', nothing can be selected since nothing can have a single property (NAME) that is both.  You need to explicitly set each line as logical OR.
Rail Community
