Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Find Item - filter items by wing of a building
4 REPLIES 4
gustavomello
409 Views, 4 Replies
Hi to all, i'm trying Navisworks Manage 2014 here. Up to this point i managed to use searchs with success.
What i would like to do now is refine the search by wing, for instance select a type of door located in a wing of the building. This way i can set which elements will be built first on the timeliner, considering that diferent wings would be built at diferent days. Initially i thought in using scope boxes but haven't found a association between items and them, so now i'm stuck.
Is there a way of associate items to scope boxes in navisworks?
Is there another way of filtering the items by wing?
Thank you,
Gustavo
4 REPLIES 4
Logos_Atum
in reply to: gustavomello
Hello there,
I would be interested in this issue too!! Also a selection range
narrowed by a defined  increment would be nice to have.
kind regards
Daniel
Dogs aren´t flammable.
gustavomello
in reply to: Logos_Atum
Hi Daniel, if i find a way, will post here.
Gustavo
The only way to filter buy wings or areas right now is to add a parameter or adjust layer names to include areas that can be searched out for.
gustavomello
Until now it's the only way i see, but would be nice to have a easier method. I'm trying with the parameter, but in big projects with lots of groups is a tedious way of spending anyone's time. I found a post about this subject on augi´s whishlist, so i think i'll have to stick with parameters for some time.
Rail Community
