Hi to all, i'm trying Navisworks Manage 2014 here. Up to this point i managed to use searchs with success.
What i would like to do now is refine the search by wing, for instance select a type of door located in a wing of the building. This way i can set which elements will be built first on the timeliner, considering that diferent wings would be built at diferent days. Initially i thought in using scope boxes but haven't found a association between items and them, so now i'm stuck.
Is there a way of associate items to scope boxes in navisworks?
Is there another way of filtering the items by wing?
Thank you,
Gustavo
Hello there,
I would be interested in this issue too!! Also a selection range
narrowed by a defined increment would be nice to have.
kind regards
Daniel
The only way to filter buy wings or areas right now is to add a parameter or adjust layer names to include areas that can be searched out for.
Until now it's the only way i see, but would be nice to have a easier method. I'm trying with the parameter, but in big projects with lots of groups is a tedious way of spending anyone's time. I found a post about this subject on augi´s whishlist, so i think i'll have to stick with parameters for some time.
