Navisworks General Discussion
thniels
Message 1 of 6 (273 Views)
File Save Options Setting a default
273 Views, 5 Replies
02-25-2014 06:27 AM
We find ourselves constantly changing frame rate from 6 to 24 in File Options in Simulate. Is there a way to set this value by default or is it bound into the software?
Distinguished Mentor
JoAnn_Hogan
Message 2 of 6 (269 Views)
Re: File Save Options Setting a default
02-25-2014 06:43 AM in reply to: thniels
There's no actual place to reset the default FPS to a personal setting. That is part of the Navisworks program as a standard. Only the developers can change that. However there are a few settings that we have found applicable namely:
  1. Change the Frame Rate manually
  2. In the options Editor dialogue box > under display > deselect "Guaranteed frame rate"
  3. Options you can change in your export dialogue box for FPS
Those are the only variables you can change
Please let me know if this helps
Jo (P.S follow me on twitter @JoAnn_Hogan)
If this post solved your issue please mark as solved and Kudos are always welcome =)
AutoCAD Certified Professional 2014 / Inventor Certified Professional 2014
thniels
Message 3 of 6 (263 Views)
02-25-2014 07:47 AM in reply to: JoAnn_Hogan
Ah, that's a pity. So what you are saying is, that we need to send some of our famous Danish cookies to California and wait a bit while the developers munch away :smileyhappy:. Or, in other words: I really think this should be possible - the entire File Options dialog should be set in XML.
JoAnn_Hogan
Message 4 of 6 (258 Views)
02-25-2014 08:26 AM in reply to: thniels
You could post this idea in the IdeaStation. So they know what to work on while munching away
thniels
Message 5 of 6 (223 Views)
03-03-2014 04:51 AM in reply to: JoAnn_Hogan
Oh, there doesn't seem to be an IdeaStation for Navisworks. Am I missing something?
JoAnn_Hogan
Message 6 of 6 (219 Views)
03-03-2014 04:59 AM in reply to: thniels
http://www.augi.com/ Is the best place to post your ideas for now. Hopefulle they will create one for the community soon.
Have API Questions?
New Dedicated Forum for Navisworks API
