hello friends
I have a serious problem in the export of native RVM file AVEVA PDMS to Autodesk FBX file.
Since my idea is to transport the AVEVA PDMS model to Autodesk 3dmax to create a stage environment with animation and real material thing with AVEVA Review can not be done, much less with the Autodesk naviswork
I draw the pdms rvm and then I export to Autodesk naviswork because there is no direct export to 3dmax
The naviswork it works to perfection right there and do the export to FBX but when you export to 3dsmax FBX through a freeze on the model, it is impossible to work in
I would like to know if anyone has had the same problem as it is too time than it takes to load the FBX in 3dmax
You try everything I canceled during the export lights, cameras, and textures, I've also updated the FBX plug-ins to the most current but I still have the same problem
