Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Failed install Navisworks Freedom 2014 on Surface PRO
3 REPLIES 3
1715 Views, 3 Replies
During the install it gets to the point where it tries to install .net 3.5 and displays a message indicating that it can't connect to the internet.
The internet connection is rock solid.
Any idea on how to solve this?
3 REPLIES 3
KOGOK
To resolve this, I had to bring up a Search Box and do a search for Windows Features. Tap Settings, and select "Turn Windows features on or off". From here select .NET Framework 3.5 (includes .NET 2.0 and 3.0). Once you do this, it'll download and install .net Framework required for Navisworks. Install Navisworks Freedom and you should be good to go.
in reply to: KOGOK
Will this work for the Surface Pro 4 running windows 10?
Patrick_Aps_9121
Is your Windows 10 32-bits or 64-bits ?
Freedom 2014 was released in 32-bits and 64-bits versions
Freedom 2015 and higher was only released in 64-bits version
Rail Community
