Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Failed Install - Navisworks Freedom 2013
3 REPLIES 3
labeneke
5808 Views, 3 Replies
Hello All,
I'm having difficulty installing Navisworks Freedom 2013 on a workstation.
The install file is Autodesk_Navisworks_Freedom_2013_Multilingual_Win_64bit.exe.
It is being installed on Windows 7 Professional SP1 64-bit with 16GB RAM and 233GB free disk space.
The install fails whether logged in as the local administrator or as the domain administrator.
The install file has been downloaded twice in case the first attempt was corrupted.  Both display the same error.
It completes the file expansion, begins setup and then displays the error...
   "The system cannot open the device or file specified.
    C:\Users\ADMINI~1\AppData\Local\Temp\_AICCEF.tmp\x64\NAVFREE\freedom.msi"
If freedom.msi (above) is manually executed from Windows Explorer, it displays the error...
   "Error reading from file:
    C:\Users\administrator\AppData\Local\Temp\_AICCEF.tmp\x64\NAVFREE\Autodesk\Navisworks\Freedom2013\MRF\Setup\MC3.dll"
The Windows Event Viewer (eventvwr.msc) logs the latter error (event 11309), but not the former.
I'm stuck.  And idea what could be wrong?
Lane Beneke
Southern Piping Co.
3 REPLIES 3
labeneke
in reply to: labeneke
Not sure why this made a difference, but...
This computer had previously had AutoCAD 2010 through AutoCAD 2013 and Navisworks Manage 2013 installed.  They had all been uninstalled, but their folders still remained in C:\Program Files.  We manually deleted those folders.  Then we deleted the contents of the temp folder (C:\Users\administrator\AppData\Local\Temp).  Then we rebooted the computer, logged in, and re-ran the install... and it worked.
I did all these steps and still getting the same error.
Cleanned all temp files, restarted several times win 7 64 bits and still the same.
I've downloaded Navisworks Freedom only and tried to install , same error.
I've downloaded Navisworks manage 2012, same error.
I don't know what to do ...
Someone can help me?
Just reminding the error:
Autodesk Navisworks Manage 2013
O sistema não pode abrir o dispositivo ou arquivo especificado.
C:\Users\vitorvti\AppData\Local\Temp\_AI38CB.tmp\x64\NAVFREE\freedom.msi
OK
labeneke
I've experienced the error again on a different PC. The fixes from the earlier install did not work a second time. Ultimately, I had to format the drive and re-install Windows. Lane Beneke – Network Admin Office: 252-291-1561 x1148 Direct: 252-265-5401 Mobile: 252-205-6795
Rail Community
