Using NWCOUT command I export an ASD model and when I open the file in Navisworks, all the welds and bolts separate from the model. It appears as if these objects are double the scale of the rest of the model.
Any help would be much appreciated.
Hi Patrick,
Sorry, ASD - AutoCad Structural Detailing. I also thought that maybe it had something to do with units ie. metric / imperial, but everything is metric.
The model comes in scaled correctly. The bolts and welds are double the scale, but are also offset from the rest of the model.
To my knowledge, in Navisworks, if you are able to select these welds and bolts using Select Sets, you would only be able to hide them or change the color. So you could not scale only a part of an NWC file.
So the solution must be found at the ASD plug-in of Navisworks. Do you have options over there ?
If not, the only option left is to uninstall the plug-in and install another (older) version to try.
