I have a file *. Nwd (Naviswork).
It 'possible to export the model directly into Revit or Autocad Detailing?
If so, how can I do?
Solved by dgorsman. Go to Solution.
No. Thats one of the points of NWD - the model can be shared without others taking content or creating construction drawings without authorization. Check your contract, it will detail whether you have rights to the original models. Because the model is converted for use in Navisworks, trying to make drawings from something that has been converted, and converted again, would be highly suspect for accuracy and content.
