Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Export from Naviswoks
2 REPLIES 2
andrea_pontiggia
483 Views, 2 Replies
I have a file *. Nwd (Naviswork).
It 'possible to export the model directly into Revit or Autocad Detailing?
If so, how can I do?
Andrea
2 REPLIES 2
dgorsman
in reply to: andrea_pontiggia
No.  Thats one of the points of NWD - the model can be shared without others taking content or creating construction drawings without authorization.  Check your contract, it will detail whether you have rights to the original models.  Because the model is converted for use in Navisworks, trying to make drawings from something that has been converted, and converted again, would be highly suspect for accuracy and content.
No, not Direclty
You can export to FBX and that is convertable to DWG but you loose all data and keep only the model data
Rail Community
