Every time I try to merge a dwg file, I get an error message. See attached image, then if I click on retry it gives me another message. I am using Navisworks Manage 2015.
Please help!!!
The error message "has an unknown version number" could mean the DWG was not created by an Autodesk product OR is was created with a higher version (like AutoCAD 2015) that your Navisworks is unable to read. As your navisworks is also 2015 this 2nd possibility is unlikely.
As a test and workaround, If possible, try opening this DWG with AutoCAD, and try saving as an AutoCAD 2010 DWG. Then try appending this DWG in Navisworks.
i have the same error and have down saved to 2010.
The DWG was created using Revit 2015.
try to AUDIT e PURGE on DWG file
i have done a purge but not an AUDIT.
btw it appends fine in Simulate 2014.
Has anyone had luck resolving this issue? I have having the exact same problem.
