Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Display line Number Tag in navisworks
5 REPLIES 5
kumarswapan64
7375 Views, 5 Replies
Line number tag not displaying in navisworks only File name is displayed. Please see the snapshot.
How it will come?
Please help.....
Swapan Kumar
5 REPLIES 5
I am assume you created this model in Plant 3D. How you exported the model in Plant 3D to Navisworks?
By open directly dwg file or with NWC export utility ?  . The utility link below :
http://www.autodesk.com/products/autodesk-navisworks-family/autodesk-navisworks-nwc-export-utility
Please make sure you had already object enabler for Plant 3D
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21330574&linkID=10382102
Object enabler for the Plant 3D should be the same version with your Navisworks.
Arief Rahman
Yes the Piping model was created in Plant 3D.
In Naviswork by clicking Append all the the files in the projects and created .NWC or .nwf files.
Link you have give for Navisworks 2014 & Autocad Plant 3D Object enabler.
I am using still Autocad Plant 3D.
Please provide me the link of Autocad Plant3D.
Swapan Kumar
It is confirmend that Object enabler for Plant 3D is already there.
I have installed   "Autodesk Navisworks Exporters 2013 Multilingual win.exe".
How can I use NWC Export utility?
Nowhere it is appearing in Menu bar or Toolbar.
please help me
Swapan Kumar
still i haven't received any reply.
please help....
Swapan Kumar
The NWC export utility is an add-on to AutoCAD Plant 3D
Start AutoCAD Plant 3D, open the model, set your visual style the way you want and then command: NWCOUT
Rail Community
