Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Depolyment Issues
4 REPLIES 4
309 Views, 4 Replies
Depolyment Issues
I have made a depolyment image and we have issues in depolying this across 400 plus users?
Q1. How do you deploy the image to 400 plus users via gpo?
Q2. Is there a msi that i use to deploy via gpo?
Any help on this would be a great help.
Supportlbs
4 REPLIES 4
Patrick_Aps_9121
I install the software by using a batch file that can be selected
rightmousemenu -> Run As Administrator
the batch file only contains a line that launches the link created by the "create Deployment" wizard.
START /Wait \\Servername\Share\FolderPath\NavisWorksFreedom2014\AdminImage\NavisWorksFreedom2014_32bits.lnk
use no spaces, only underscores in the path and the Deplyment name.
Perhaps you could deploy such a bach file using your tool ?
in reply to: Patrick_Aps_9121
Thanks for the info,
Also one more question.
Q1 How do i get the image onto a machine which has already has the software installed?
When i try doing this it says Setup on the dialog box and disppears. Then i launch the application again and the new custom image has not been installed.
Mike
Patrick_Aps_9121
If you have a machine with the same version (2013 /2014) and flavour (Simualate, Freedom) installed,
but from a manual install or another deployment, you should uninstall first
You can check in a batch file like this
IF EXIST "C:\Program Files\Autodesk\Navisworks Freedom 2012\Roamer.exe" echo Freedom 2012 found
You can launch the uninstall of Freedom 2013 like this
C:
CD "C:\Program Files\Autodesk\Navisworks Freedom 2011\Setup"
IF EXIST Uninstall.exe START /WAIT Uninstall.exe /QB /W /T /P {35738946-FE22-0000-8916-2CE9119C21D5} /R FREEDOM32
I got the syntax from the unisntall string in the registry.
Hi
Also what about Manage 2013 and Simulate 2013 uninstall batch files.
Rail Community
