A DataTools connection was set up in NWM 2012. The linked data does not work in NWM 2013. The linked data still comes in fine when the same file is opened in NWM 2012. Windows 7 64-bit, NWM 2012 & 2013 64-bit, Access 64-bit.
DBQ and DefaultDir are identical in both NWM 2012 and NWM 2013 SQL String is identical in both NWM versions as well.
Are any changes in the ODBC set up required in Navis 2013?
Thank you,
Joe Menacker
I recreated the link setup from scratch and all seems to be working find in 2013. Not sure why the 2012 setup did not work in 2013.
Joe Menacker
