Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Data Tools error
3 REPLIES 3
2332 Views, 3 Replies
Data Tools error
I have tried to create a Data Tools Link called 'test' to excel but when activated get the error message 'Unable to set one or more links to active due to insufficient/invalid information. Setting them to inactive.' If I remove the WHERE statement from the SQL String then I dont get the error message but I dont get a new tab in Properties either. Screen shot of link attached. I'm using Navis Simulate 2013, Fabrication 2013, Office 2010, WIndows 7 all 64 bit. Can anyone tell me what I'm doing wrong. Many thanks
3 REPLIES 3
Lance.Coffey
I found the following guide for using DataTools with Excel:
http://revittoday.blogspot.com/2009/03/how-to-link-excel-using-datatools.html
It was written for the 2009 version so some things are in different places, e.g. Samples folder instead of Examples folder, but it looks like you should be able to adjust the steps for the 2013 version, and get a working connection setup to test.
Lance Coffey
Technical Support Specialist
in reply to: Lance.Coffey
Lance,
Thanks for this suggestion. There was a problem with my spreadsheet. I used the example as a template and now it is working correctly.
Is there a way of bringing a website link in excel through into Navis so you can click on the link in the properties tab? At the moment it just brings the link through as text.
ilkka.tuulaniemi
I have also tried to create a Data Tools Link, to excel, but when activated get the error message "Unable to set one or more links to active due to insufficient/invalid information. Setting them to inactive."
The problem pops up unexpectedly, I transferred the data two hours earlier without any problems, but now I can't. i have Simulate license which is up to date.Can anyone help me with this problem?
Best regards: Ilkka
Rail Community
