Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Cylinder / Primitives Disappearing from Model
4 REPLIES 4
andrewmcminn82
263 Views, 4 Replies
When i open my model in Simulate 2012 some of the cylinders / primatives disapear, usually every new model converted from PDMS works fine first few times then it starts to not load / open / show the cylinders.
This model is made up of AutoCAD items and NWD's, then once compiled saved as an NWD.
4 REPLIES 4
in which type of file are the Cylinders located ?
If these are DWG files, try deleting the NWC file of that.
No these are the NWD's created from the PDMS export.
it only seems to be me that has this issue, i have tested another computer with exact same model and it works fine so it has to be my settings somewhere.
I have also deleted my cascadeinf.cas file to see if that was the issue
Check versions / Service Pack / Hotfix numbers between the computers
if they are the same Export and Import all options from the good one to your computer
Rail Community
