Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Custom Item Calculation Formula
2 REPLIES 2
756 Views, 2 Replies
Background:
I can append my Revit file
I've managed to alter the "TakeoffPropertyMap1.xml" file to map my Revit reinforcement density variable to the Navis Quantification variable ModelWeight
All my Family and Types in Revit have been setup such that they will create the right Quantification Workbook structure
Goal:
I was hoping that there was a way that when takeoff the whole model, the variable for Weight in the Item Catalog would have the formula "=(ModelWeight/1000)*ModelVolume" so that I can get the correct quantity for reinforcement.
Any assistance would be greatly appreciated.
Thank you.
Carl
2 REPLIES 2
Once you alter the xml file for density variable, create a Item in your workbook and "Take off" all the steel in that Item. then enter your formula in the reporting column "Weight" (not "Model Weight"). Then the formula will be applied to all the rows in that column.Capture.PNG
Yeah.  I'm aware of this and it would be fine if I had a few items. But, as I mentioned, I have already taken off the model to the Quantification Workbook.
There are over 2000 items within the model and it is too much to ask someone to edit the formula within the Item Catalog for each instance.
I was hoping that there was some way, similar to editting the TakeoffPropertyMap.XML, where I could alter the fomula for Weight such that:
Weight = (ModelWeight/1000)*Model Volume
The ModelWeight is reading correctly and the above fomula does not change.
Rail Community
