I am having trouble opening NWF files. I can create and save without an issue. When I open the file the next day I get an error and it says the contents are corrupt. I have not had this error on any other version and I cannot find the issue. I have tried to save all the appended files as different names and NWF's or NWD's and nothing is fixing this issue. Has anyone else had this problem? Does anyone know what the fix is?
Solved by timothy.mcnamara. Go to Solution.
Thank you for your post. In this case it looks like you are seeing some corruption behaviors with your NWF files within the Navisworks software.
I have seen this a number of times and typically relates to a corrupt project file itself. In some small cases it is attributed to a problematic linked model that needs to be resaved (if in native format) or a new NWC cut from the host software to add back in. Again, most times it is a corrupt NWF file though (project file). To overcome this issue, please create new NWF to add in your pinked models to then rebuild the NWF. Once rebuilt, please then retest and confirm the issue is now resolved.
If the issue is not resolved, please upload a sample of the NWF and linked models for testing. Thank you and we look forward to your reply to best help in this post where applicable.
