Hello there,
is it possible to combine timelines of different Navisworks files in order to match
the end of sequence A with the beginning of sequence B?
Doing this manually surely is not a good practise.
Kind regards
Daniel
Solved by Holger.Kloecker. Go to Solution.
I think what you want to achieve is not possible - did you notice this statement from the Navisworks help:
http://help.autodesk.com/view/NAV/2014/ENU/?guid=GUID-79DE7F56-59CF-4786-A31D-170E11BF89EC&p=NAVFREE
Hello Holger,
thanks for the in- depth information. It´s okay anyway
and also understood. Is it possible to change the time-
liner preset to 7 days a week?
And could you have a look at the FBX vs. Inventor im-
port troubles I´ve been dealing with?
Kind regards
Daniel
