I am using Navis Manage 2015. When append a the file with two seperate autocad drawings they do not line up. They are in the same coordiate system and reference into each other correctly. Any idea?
They do not share a a common UCS.
One is different....Or one has been moved when referenced into the other.
They are in the same UCS. I found the problem, for some unexplained reason in Navisworks the one model was set to millimeters under Units and Transform Setting. When I changed it to feeet it fell right into place.
