The only solution is to use Simulate to convert the LaserCloud into an NWD.
Then you can view the cloud in Freedom. Because Laserclouds tend to be huge files, be aware of what you are doing.
If you want only part of the LaserCloud, you need another tool to cut out the part that you need.
If you want to combine the LaserClout and other models, then you need Simulate again to combine the NWD of the laserCloud and the other models and save that as another NWD.
