After running the clash detective, is there a way to get the clash names, locations, levels, assigned to, priority, etc, etc... all into an excel spreadsheet?
Solved by dave.wolfe. Go to Solution.
The HTML reports might be openable in Excel directly. You could also take XML reports and pass them through a transform to make them more friendly (I think they are a little flat to open directly).
Did this answer your question or not?
http://forums.autodesk.com/t5/Autodesk-Navisworks/viewpoint-report-to-excel/td-p/3557526
I take that back...
What about "saved viewpoints" and not ones generated from the clash test.
I know you can export each picture by itself, but that will take entirely too long.
I created my own viewpoints and saved them, any way to export those?
