Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
clash detection for ifc file
3 REPLIES 3
1447 Views, 3 Replies
Hi Expert, As we know, Navisworks provides good operation for clash detection. I want to know whether it is good to support IFC file. Which means if I use clash detection function to test clash for IFC file, whether I can got correct result
Gavin
Tags (2)
3 REPLIES 3
Patrick_Aps_9121
I have used IFC a files a lot and never experience unreliable data in Navisworks with it. Everything was shown correctly in Navisworks so was clash detected also correctly
IanBadcoe
NW reads IFC files and there is no reason why you cannot clash detect with them.
One small worning, IFC files can come from many different applications and there is a lot of variation in what they export and how they structure.
If you get some typical IFCs that you want to use, load them into NW and inspect them, then as long as the you see everything you expect to see in NW, then you should be good to go.
Ian
in reply to: Patrick_Aps_9121
Thanks for your response, it seems NW can operate IFC file well.
Rail Community
