I am trying to do a clash detection but when I "run test" the model screen goes black but the "results" list the clashes. If I select a clash the screen remains black. While "results" tab is selected I can select other saved viewpoints and the model appears, but showing no clashes.
that error only appears when you use "Run Test"????
Yes, everything is running fine up until I "Run Test". So when I create a new test and go to results, it does show me all of the clashes in the list. But when I select a single clash the model goes black. I've discovered if I select another "Saved Viewpoint" the model appears in wireframe form and the clash is highlighted. The clash isn't zoomed into and I have to orbit/zoom/pan until I find the selected clash. As I click through the other clashes the model screen goes black. For the clashes that I have -- chosen a new "saved viewpoint" and located -- when go back to select the clash it does show up. So as of now, if I go through every single clash, choose a new saved viewpoint, orbit/zoom/pan they will show up.
I have exactly the same problem. Have you gotten any resolution finally?
What is the cause of the issue?
Thank you in advance,
Emma
