Hi all.
I recently installed Factory Design Suite 2014 on a fresh Windows 8.0 machine.
It seems that I cannot load the Navisworks menu in Acad-A for some reason related to rights.
I have checked the LwNw_Export.mnu file and the folder it ersides in:
C:\Program Files\Common Files\Autodesk Shared\Navisworks\2014\nwexport2014\nwcreate_data11.
Both were write protected and the rights set to read only for all users.
I have changed it but it still wont work.
Please help, I need the menu for demo purposes.
Also, I can write the command nwcout after loading the nwexportdbx2014.crx (why is that not an arx as before?) in C:\Program Files\Common Files\Autodesk Shared\Navisworks\2014\nwexport2014,
and nwopt also works, but
but the command nwnavigator hangs Acad-A after message:
.NET-BroadcastEventWindow.4.0.0.0.3917f2.0: lcnavigator.server.exe - Cannot find the start adress
Det går inte att hitta procedurstartadressen ?MakeTempFileNameW@LcUSysFile@@SA_NPEB_W00PEAVLcUWideStringBuffer@@@Z i DLL-filen C:\Program Files\Common Files\Autodesk Shared\Navisworks\2014\ActiveX Redistributable\lcodieDX.dll.
BTW: Why, why why does Autodesk have to always hide menu files and arx:es in such obscure places, and why aren´t the menu file for Navis have the extension cuix lika all the others? I think I spent a whole hour trying to find the bugger! It should be a cuix and all menufiles should be in the SAME place! Time and again, because the crx (!) and menu does not load after installation, I have to look for these files. Every time I forget where they are.
I know all that.
But I think that the option to create an nwc and nwd from inside Acad is a nifty feature and I want to be able to show it.
The question is: How can I get the menu and the commands to work on my machine?
BR
/Gunnar L.
Yes it´s a standalone.
I am full admin and my company doesn´t use policies that restrict users, so there has never been any blockig like that. although I notice more and more that a full admin on Windows 8 is not quite a full admin anyway! More built-in restrictions than in W7.
I have installed all the servicepacks and the patch DL21985761_64-bit
Still no luck.
When I try to load C:\Program Files\Common Files\Autodesk Shared\Navisworks\2014\nwexport2014\nwcreate_data11\LwNw_Export.mnu
(what a path!)
--I still get the message:
Write permission denied. Unable to create: 'C:\Program Files\Common Files\Autodesk Shared\Navisworks\2014\nwexport2014\nwcreate_data11\LwNw_Export.cuix'
The crx loads fine, but some commands doesn´t work.
So, I looked up the path C:\Program Files\Common Files\Autodesk Shared\Navisworks\2014\nwexport2014 and it was (again?) write protected!
I changed that and also changed the rights of all users to "Full".
I did the same on C:\Program Files\Common Files\Autodesk Shared\Navisworks\2014\nwexport2014\nwcreate_data11.
Problem solved! Now it works, all of a sudden.
Conclusion: Windows 8 is more restricted than W7. Therefore the installation path should be changed to a common place where users have rights from the start.
Ooops! I was a bit too quick.
The menu loads, but is it the right one? It has no ribbon in it, and I seem to remember that there should be one?
The command nwnavigator still gives me the message:
.NET-BroadcastEventWindow.4.0.0.0.3917f2.0: lcnavigator.server.exe - Det går inte att hitta startadressen ( The start adress cannot be found)
OK
i also have windows 8
and running Factory 2014 and running this command also produces the same error message
DarrenP
I too have the same situation on Windows Server 2012 (very similar restrictions to Windows 8).
Everything is fully patched:
Navis 2015 SP3
Latest 2015 Exporters
Set Security to Full
My path is: C:\Program Files\Common Files\Autodesk Shared\Navisworks\2015\nwexport2015\nwcreate_data12\
MENULOAD does load, but when I open AutoCAD MEP I get a warning about it being an untrusted location and I select "Trust" and the warning goes away, but I cannot get a menu at all
Why, oh why, is this such a ridiculous process? Navisworks is a primetime product (and owned by Autodesk for a LONG time now BTW).
Maybe you guys want to call up Bluebeam since Revu installs and loads an Export tab full of reasonable features.... just by default installation. What a concept! They employ the programmers, I buy the program and USE it. Notice there's nothing about me programming...
I also now installed FDS 2015 and I still have to load the menu manually.
The path for 2015 is
c:\program files\common files\autodesk shared\navisworks\2015\nwexport2015\nwcreate_data12\lwnw_export.cuix
To get it to load at all, I had to remove the write protection and change security settings on the folder
C:\Program Files\Common Files\Autodesk Shared\Navisworks\2015\nwexport2015 to full for all users.
Then when trying to load, I get the warning about trusted locations. I clicked "Load".
Since there is no ribbon in the menu file, I also had to write the command "Menubar" and set it to "1".
Now there are old style menus for "Raster", "Express" and "Navisworks" at the top of Acad ADT, above the ribbon tabs.
This is not very nice, I would want to get buttons and a tab for Navis in the ribbon!
The menu commands seem to work this time though.
Autodesk: Please fix this load procedure to be automatic and fix the ribbon for Navisworks! Please also add the command "export to nwd" as it was before.
NWD export is gone and not coming back, from the same decision that gave free and no-license-required NWC exporter plug-ins. Have a look at the scheduled publishing system - far, far superior method of generating NWDs.
Trusted locations in AutoCAD verticals isn't going away, and is part of an ongoing process of adressing rising security concerns. This can configured to suit individual needs or turned off altogether.
Not sure what there is to fix about the Ribbon, as you note there isn't a panel in the first place. Do you mean create a Ribbon panel? Menus and toolbars can be converted very easily (one of the easiest things in the CUI editor, in fact). It might be nice to have them do it for you, but I wouldn't classify it as a bug. I would suggest making a feature request as posts in the forum don't get input into the system.
Oh, for the other poster: I don't recommend running desktop software on a server OS. While similar to a desktop OS there are enough differences they aren't supported.
