Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Can't multi-task Navisworks & CAD
1 REPLY 1
439 Views, 1 Reply
Hello Gentlemen.
I am having problem with multi-tasking Navisworks Manage 2011 & AutoCAD 2009.
When I run Navisworks first and CAD later, CAD command is not active.
On the other hand, when I run CAD first and Navis later, Navis command is not active.
It happened 3 days ago. (Before, there was no problem to run Navis & CAD at the same time.)
Un-installation & re-installation has done several times. Still I can not solve this matter.
Do you have any idea? Please let me know.
1 REPLY 1
lee.mullin
You may need to load the ARX plugin in AutoCAD as shown from the help files below
To load the ARX plugin in an AutoCAD-based application
Type ARX at the command line.
Press Return.
Type the letter L (for ‘Load’) at the command line.
Press Return.
In the Select ARX/DBX File dialog box, browse to the ARX plugin.
Note. For AutoCAD 20xx based applications, the plugin is located under C:\Program Files\Common Files\Autodesk Shared\Navisworks\2011\NWExport20xx\nwexport20xx.arx. So, for example, for AutoCAD 2004 based applications, the plugin is located under C:\Program Files\Common Files\Autodesk Shared\Autodesk Navisworks\2011\NWExport2004\nwexport2004.arx, and so on.
Click OK to load the ARX plugin.
Let me know how you get on.
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
Rail Community
