SP3D generates xml file while generating Vue file. This xml file is nothing but information of all the data , attributes which SP3D stores. Someone has tried importing this xml into Navisworks?????
I have created animation for SP3D Plant Model with using Navisworks. Creating dgn files from sp3d model and then importing dgn into Navisworks. It worked really smooth for me. For creating animation i dont require model data attributes information. This way you can use the naviswork for atleast making good animation.
Is there any progress in this matter? We have to open .vue files from our contractors and we consider that Navisworks will be prefered way. But only DRI (Old Intergraph) can be imported in Navisworks.
We have the solution for that purpose.
3D Apps Exchange can convert 3D PDF from SmartPlant Review.
1. SP Review load VUE then export 3D PDF
2. 3D Apps Exchange rebuild the hierarchy and metadata, grouping elements then converts to NWC
It supports 3 output formats
- NWC for a serious Navisworker
- 3D DWF for Synchro 4D simulation
- 3DXML for Enovia PLM solution
It was requested by INPEX and SHI(Samsung Heavy Industries).
SHI use SmartMarine3D for HULL, AVEVA PDMS for Topside. they wanted to view all in Navisworks.
I would say it is a "Persuasive Technology"
for more information please visit www.eDesignReview.com or www.Intra.co.kr
or contact me directly.
-tc
Dear Team,
The Smart plant review 3D exported pdf has custom views .
is it possible to control views selection in exported pdf file using c#?
The VUE Viewing project is alive and well on Autodesk Labs. A new version was just posted and many improvements and fixes have been made.
Go to labs.autodesk.com and register, sign in, download and install the VUE file loader technology preview and provide feedback on the project forum there. There is also downloadable documentation there which you'll want to review.
Regards.
Roger
Our new solution for Intergraph SP3D is Direct Database Expoter.
this solution is 50x~100x faster than SmartPlant3D VUE file extraction.
it is designed for huge model conversion to Navisworks NWC, Dassault Systemes V6 and Unity3D.
it has NWC conversion, Daily change list (added/deleted/modified) for change update in downstream workflow and incremental update for Dassault.
If interested, please contact me.
