Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Basic problems with Quantification
1 REPLY 1
noachergai
507 Views, 1 Reply
Hi guys!
I have two problems with Quantification:
1) Quantification not see correctly the layers of the wall imported from Revit.
2) Using a Revit file directly imported or exported with the plugin Navis, the quantities that characterize the walls (height, width, volume, area ...) are still zero!
Previously I included this topic also in the Augi forum http://forums.augi.com/showthread.php?151945-Revit-Quantification-basic-problem
I discovered that the problem of the layers of the wall can be solved, making sure to make an assembly before exporting the file or import it into Navis. But I ask you: is normal that Navis does not see the layers of a wall system Revit?
thanks
1 REPLY 1
noachergai
in reply to: noachergai
Italian edition of Quantification (in Simulate 2014, BDS Premium) simply don't works. All zero quantities.
Trial english Manage 2014 little better: few quantities.
Autodesk?
ps: SP1 installed
Rail Community
