Hi!
I cant find the mdl plugin for microstation in the "Autodesk Navisworks 2015 Exporter Plugins 64bit"
This link states that it should be located under add/remove features in the Autodesk Navisworks 2015 Exporter plugins.
In NW2013 this plugin where located in the "32bit exporter plugins". Is this plugin removed or do I need to install some specific version of microstation?
Solved by Patrick_Aps_9121. Go to Solution.
I unserstand you cannot find the MDL plugin for Microstation in Navisworks 2015. If you installed the Autodesk Navisworks software with exporter plugins, and you install MicroStation software after Autodesk Navisworks is installed, you need to update your exporter plugins installation with the appropriate ARX plugins before you can use them.
Make sure you loaded the MDL Plugin:
Then add the MDL Plugin to Autodesk Navisworks Exporter Plugins Installation:
I hope this helps and thank you for posting.
Ive been using this mdl plugin for several years in other navisworks version.
The plugin is unavailable in the add/remove features in the "Autodesk Navisworks 2015 Exporter plugins"...if I cant install it i cant load the mdl.
I think its something wrong with the installationpakage....
I have a 64bits Win7 Ultimate with both MicroStation J and MicroStation V8i SS3 installed.
I have downloaded the exporters from
http://www.autodesk.com/products/navisworks/autodesk-navisworks-nwc-export-utility
Running the 2014 sfx.exe, It asked me if I wanted to install the exporters for MicroStation J and/or MicroStation V8i, which I did not, cause I needed another one.
Running the 2015 sfx.exe it dit the same, but they are listed under the AutoDesk Navisworks 32bit Exporter plug-ins, because MicroStation is a 32-bits program, no matter what version until now.
I see. In 2013 version they where included when downloading Simulate/Manage.
Thanks Patrick!
