I have an issue with elements showing wireframe from plant 3d. i've seen a few posts about this with no resolution. i have installed OE for the correct software but it doesn't work. my scene statics are still giving me this error.
'Missing object enabler for application ""PnP3dObjects |Product Desc: Plant 3dPiping'
Which object enabler, specifically, did you install? And did you install it after Navisworks?
Same problem here...
Also, multiple crashes of Navisworks 2014 when trying to open Plant 3D DWG files and also multiple crashes of FiletoolsTaskRunner.exe tu run automatic batches.
I opened several cases to Autodesk Support and still solution, Autodesk Development is working on it but I was told there may be no solution until Navisworks 2015...
Good luck,
Alexandre Devos
