Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Autocad Layer Transparency not going into Navisworks
4 REPLIES 4
matt.worland
2488 Views, 4 Replies
This is a bump from an old thread, Thought it might get more views here.
http://forums.autodesk.com/t5/AutoCAD-2010-2011-2012/Layer-transparency-in-DWG-file/m-p/4881990#M107...
matt
If my reply was helpful, please give a "Thumbs Up" or "Accept as Solution"
4 REPLIES 4
dgorsman
in reply to: matt.worland
Thought I responded to this already, maybe it was over in AUGI.  Anyways, "transparency" in AutoCAD and Navisworks are two separate concepts even though they are functionally similar.  It *might* be possible to get it in as a Wish List item for modifying the DWG reader (somebody might be able to create a third-party Navisworks plug-in too).  In the meantime, the Appearance Profiler should greatly speed up applying that kind of setting.
matt.worland
in reply to: dgorsman
Thank you very much, and after you mentioned it, I did find your post over at AUGI.
How do we add this to the "wish list" for the developers?
matt.worland
If you are a member of AUGI you can submit these in their wishlist. The product teams have access to view the lists and see which items users are requesting.
http://www.augi.com/wishlist
matt
Rail Community
