This is a bump from an old thread, Thought it might get more views here.
matt
Solved by dgorsman. Go to Solution.
Thought I responded to this already, maybe it was over in AUGI. Anyways, "transparency" in AutoCAD and Navisworks are two separate concepts even though they are functionally similar. It *might* be possible to get it in as a Wish List item for modifying the DWG reader (somebody might be able to create a third-party Navisworks plug-in too). In the meantime, the Appearance Profiler should greatly speed up applying that kind of setting.
Thank you very much, and after you mentioned it, I did find your post over at AUGI.
If you are a member of AUGI you can submit these in their wishlist. The product teams have access to view the lists and see which items users are requesting.
matt
