i am facing a problem in navisworks 2014, while walk through.
i am trying to create a walk through animation for overall plant, and i need to indicate each individual equipment names which need to be displayed while i go near the equipment and disappear if i pass on ( display automantic name plates ).
i tried to work on discripter which is in inventor and appent to navisworks but it doesn't work.
i also tried on asset tag in inventor i haven;t find any result.
i also tried add text and add tag in navisworks but no result
we have factory design suit 2014,
i need to know the solution as soon as possible as by project is delayed only because of this.........
You could look into the Animator. It has "hotspot" triggers which allow an animation (such as showing a hidden object - nameplate) when the camera position gets to it. But that only works in live navigation and will not work for for exported animation (movies). In order for it to work with an exported movie you'll need to set it up with the Animator and manually set the timing. Its also a lot of work to put into something thats holding up a project. Sometimes its just necessary to say "No" or "That cannot be done in time".
Redlines in saved viewpoints don't survive the animation process. They would have to be rendered out as separate frames, and compiled back in later. Might as well use the editing program to add labels as well with that process.
Thanks for your reply, But i can't understand what you are trying to say if there is any video to this explaination please post it. So that i can understand better.
