Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Appending sketchup trouble, error 32771
8 REPLIES 8
Message 1 of 9
kwurts
4498 Views, 8 Replies
I am trying to append a sketchup 7 file into navisworks but I keep getting this error: f
ile.skp has an unknown version number
failed to load file via NoW64 (hr=0x80004005)
error code:32771
I have tried different sketchup files into different Navisworks files with no luck. Does anyone know what this error is or how to get around it? Thanks.
8 REPLIES 8
Message 2 of 9
JeffH_ADSK
in reply to: kwurts
Hi there,
Unfortunately Sketchup 7 is not supported in Navisworks at this time. It is a format we would like to add but are unable to do so at this juncture.
Sorry to be the bearer of bad news,
Jeff
Senior Software Engineer
Navisworks
Autodesk Ltd.
Message 3 of 9
kwurts
in reply to: JeffH_ADSK
Thanks for your response. Do older versions of sketchup work?
Message 4 of 9
JeffH_ADSK
in reply to: kwurts
Hi there,
Yes Sketchup 6 should be supported.
Hope that helps,
Jeff
Navisworks
Autodesk Ltd.
Message 5 of 9
kwurts
Thanks again. With your advise I was able to downsave the sketchup file and bring it into Navisworks. Much Appreciated.
Message 6 of 9
in reply to: kwurts
I am not having any luck dealing with this error.  I saved my sketchup file to version 5 and tried to load it into Navisworks but I still keep on having this error.
Willie
Message 7 of 9
minimattsmith
I've started having this trouble as well and I think it's to do with the file size of the sketch-up model, it seems anything over 10mb won't open for me, but everything that's smaller does.
Message 8 of 9
michael_coffey
in reply to: kwurts
I'm having a problem appended a sketchup 5 file into manage 2012.  but i'm getting error code 32769.  my skp file is 1.8mb.  any ideas?
Message 9 of 9
Turns out I had to break down my sketchup model down into managable sizes, by doing several save as version 6's and stripping back different parts of the site, ie just vehicles, just hoarding, etc and then append those bitesize models into Navisworks. The largest file was 10.6mb it took a little longer to append that one but it still came in.
Rail Community
