Hi There
I am trying to find out why I dont have the option to delete appended files.
File is .nwf with .nwd files appended the .nwd was created from Microstation.
I right click the file in the selection tree, but there is no option to delete???
Regards
Shane
I always use the "Del" button on the keyboard to detach models from the selection tree.
That should work. Do not forget to use Save or Save As to save the changes in your NWF.
This sounds strage.
Do a File -> Save As .
-> There are no messages preventing you from saving ?
Is it a NWF or an NWD you are working with
In the selection tree, set it to Compact view
Select the file you want to "Detach"
Right Mouse Menu -> Delete
OR
Press Delete on your keyboard.
Hi
It saves as normal I am working on nwf. Have tried all off the above.
Regards
Shane
