I have made in the animator a few animations sets with several keyframes. Is it possible to move a complete animation set at once in the animator timeline viewer, without removing the keyframes one by one??
not sure if I understood correctly what you are trying to achieve.
You can assign an Animation set to a Timeliner activity using the "Animation" column.
This needs to be enabled however - it's disabled by default.
You can do so by clicking on the column button.
Does this help?
