I am making a walkthrough animation in Navis works manage 2013 and i created 2 animations for single plant.
I want continuity in 2 animations after converting to avi format. Is there any option to copy all the frames from one animation to copy to another animation?
Naveen
What is the source of your animation? Did you create it using the Animator, or Saved Viewpoint/Animations?
If your source was Saved Viewpoints, you should be able to create a new animation, and simply drag/drop the previous animations into that new one. Then, render for the combination.
If all you have is the AVI files, then l recommend you look into a cheap video editing software. I picked one up for $50 called Sony Movie Studio.
Even cheaper, Blender is free (even if the UI is... erm... "quirky" would be the polite term).
I'd also move away from AVI to something with better quality.
