Hi all,
I am currently in the process of creating an animation via saved view points and an output of a couple thousand PNG image files. When I piece together all the image files through a movie making software the animation turns out to be very smooth however the lighting between different images seems to vary and creates a distracting element in the animation. It is as if the ligthing of the objects is being turned on and off throughout the animation. For the lighting settings I'm just using the "eye" feature. Has anybody had any experience with this or have any recommendations?
Thanks!
Solved by dgorsman. Go to Solution.
I think there was a recent post, either here or at AUGI, with the same issue. Look into auto-exposure settings for lighting.
Awesome! The thread on AUGI that can be found at the link below...
http://forums.augi.com/showthread.php?139934-Navisworks-presenter-changes-lighting
Thanks for the help!
