Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Adding datatools twice
1 REPLY 1
mdenheijer
492 Views, 1 Reply
We have the following problem. We have an NWD file and a database which contains additional information for the objects in the NWD. We can link this through datatools to the NWD (version 0). We publish the NWD file with database properties embedded. (version 1)
Problem 1: The NWD Model GUID (version 1) is the same as the original model GUID (version 0).
But besides this we have found a bigger issue. If I wish to connect this NWD (version 1) again to a set of properties using the datatoosl, this does not work. The datatools connection has a different name, refers to a different database and looks for different properties.
I've added the files in the attachments. Can anyone to setup a datatools connection (file based) to this file?
I had to rename the .accdb file to .doc to get it through the upload. So please rename this back
greetz mark den heijer
Tags (1)
1 REPLY 1
Thank you for visiting our forum.
Can you please post your question in the API forum:
http://forums.autodesk.com/t5/Autodesk-Navisworks-API/bd-p/600
Thank you.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
Rail Community
